Tilted walls?
Hello!
Is it possible to create slanted/tilted walls?
If not, is this a planned feature?
Thanks!
Best regards
Eugen
I guess I could use a shed roof, right?
However, there don’t seem to be roof styles…
Hi Eugen,
The only way to create titled walls is to create these walls first using Rhino solids/polysurfaces and then use the vaWallFromSolids command to convert them into walls. Take a look at this Tip: http://www.visualarq.com/support/tips/6596/
In VisualARQ 2.0 you will be able to create roof styles. (https://youtu.be/Zu2BjvLzHAY)
Cheers,
Fair enough!! =]
Thanks!
Eugen
