Hello,I have a shape of a capped cylinder. So it essentially consists of three parts: two sphere halves and a cylinder between them merged into one surface. I need to start tiling it with a parallelogram with different sides, say 9 and 10 mm. The key requirements are: (1) I would to start this tiling from a very specific position: the first position should sit at the center of that shape (intersection of two diameters), (2) the next level should start with the parallelogram offset from the previous one by half the length. I tired to sketch it on the surface. Any suggestions would be appreciated.
Related topics
Topic | Replies | Views | Activity | |
Constraining cylinders within complex geometry | 2 | 76 | November 9, 2024 | |
How to turn a surface into solid object with thickness (Offset Surface) | 6 | 1455 | May 10, 2020 | |
Newbie Help with putting pattern on a surface | 1 | 159 | January 9, 2024 | |
Connecting a list of parallelogram surfaces with each other | 6 | 754 | November 29, 2018 | |
Circular brick pattern on a dome using standard elements | 2 | 272 | March 16, 2024 |
