Can somebody help me,
It was great to create these shapes:
Option Explicit
'Script written and copyrighted by Gelfling '04 aka David Rutten
'http://www.nurbs.tk info@nurbs.tk
'Last script revision on 25 april 2004
Sub Balloon()
Dim idBalloon, idHairs, idInfBalloon
Dim arrStart, dblRadius
Dim strResult, arrOptions(6)
Dim selWall, defWalls
Dim uvDensity
Dim stepSize
Dim i, CP, radAuto
selWall = Rhino.GetObject("Seleccione una superficie (poli) cerrada...", 8 + 16, vbTrue, vbTrue)
If IsNull(selWall) Then Exit Sub
If IsNull(Rhino.SurfaceVolume(selWall)) Then Exit Sub
arrStart = Array(1E100, 1E100, 1E100)
Do Until Rhino.IsPointInSurface(selWall, arrStart)
arrStart = Rhino.GetPoint("Elija un punto dentro del volumen para comenzar el crecimiento...")
If IsNull(arrStart) Then Exit Sub
Loop
defWalls = ExtractWalls(selWall)
uvDensity = Rhino.GetSettings(Rhino.InstallFolder & "Gelfling.ini", "Balloon", "uvDensity")
If IsNull(uvDensity) Then uvDensity = 20 Else uvDensity = CInt(uvDensity)
dblRadius = Rhino.GetSettings(Rhino.InstallFolder & "Gelfling.ini", "Balloon", "Radius")
If IsNull(dblRadius) Then dblRadius = 1 Else dblRadius = CDbl(dblRadius)
stepSize = Rhino.GetSettings(Rhino.InstallFolder & "Gelfling.ini", "Balloon", "stepSize")
If IsNull(stepSize) Then stepSize = 1 Else stepSize = CDbl(stepSize)
idBalloon = "Nothing"
idHairs = Array("Nothing")
Do
Rhino.EnableRedraw vbFalse
Rhino.Prompt "Generating preview..."
Rhino.DeleteObject idBalloon
Rhino.DeleteObjects idHairs
idBalloon = AddBalloon(arrStart, dblRadius, uvDensity)
idHairs = AddGrowLines(arrStart, dblRadius, stepSize)
Rhino.SelectObjects idHairs
Rhino.EnableRedraw vbTrue
arrOptions(0) = "Insertion_Point"
arrOptions(1) = "Radius"
arrOptions(2) = "AutoRadius"
arrOptions(3) = "Density_" & uvDensity
arrOptions(4) = "Stepsize"
arrOptions(5) = "Infl8"
arrOptions(6) = "Quit"
strResult = Rhino.GetString("Inflación sólida...", "Infl8", arrOptions)
If IsNull(strResult) Then strResult = "Quit"
If IsNumeric(strResult) Then
strResult = Abs(CDbl(strResult))
If strResult < Rhino.UnitAbsoluteTolerance Then strResult = Rhino.UnitAbsoluteTolerance
stepSize = strResult
strResult = "xxx"
End If
Select Case UCase(Left(strResult, 3))
Case "INS"
strResult = Rhino.GetPoint("Elija un nuevo punto para comenzar el crecimiento (debe estar encerrado el volumen)", arrStart)
If Not IsNull(strResult) Then arrStart = strResult
Case "RAD"
strResult = Rhino.GetReal("Especifique un nuevo radio de globo inicial...", dblRadius, Rhino.UnitAbsoluteTolerance)
If Not IsNull(strResult) Then dblRadius = strResult
Case "AUT"
radAuto = 1E12
For i = 0 To UBound(defWalls)
CP = Rhino.EvaluateSurface(defWalls(i), Rhino.SurfaceClosestPoint(defWalls(i), arrStart))
If Rhino.Distance(arrStart, CP) < radAuto Then radAuto = Rhino.Distance(arrStart, CP)
Next
If radAuto = 1E12 Then
msgBox "An error occured..." & vbNewLine & _
"unable to determine an optimal radius.", vbOkOnly Or vbError, "Dang!"
Else
dblRadius = radAuto * 0.95
End If
Case "DEN"
strResult = Rhino.GetInteger("Especifique una nueva densidad de globo...", uvDensity, 10, 1000)
If Not IsNull(strResult) Then uvDensity = strResult
Case "STE"
strResult = Rhino.GetReal("Especifique un nuevo tamaño de paso de inflado...", stepSize, Rhino.UnitAbsoluteTolerance)
If Not IsNull(strResult) Then stepSize = strResult
Case "INF"
Exit Do
Case "QUI"
ShowObjects defWalls
Rhino.DeleteObjects defWalls
Rhino.DeleteObjects idBalloon
Exit Sub
End Select
Loop
Rhino.SaveSettings Rhino.InstallFolder & "Gelfling.ini", "Balloon", "uvDensity", CStr(uvDensity)
Rhino.SaveSettings Rhino.InstallFolder & "Gelfling.ini", "Balloon", "Radius", CStr(dblRadius)
Rhino.SaveSettings Rhino.InstallFolder & "Gelfling.ini", "Balloon", "stepSize", CStr(stepSize)
idInfBalloon = InflateSurface(idBalloon, stepSize, defWalls, uvDensity)
Exit Sub
Rhino.Print "Balloon fully inflated..."
End Sub
Balloon
Function InflateSurface(idSurface, stepSize, arrWalls, GridSize)
InflateSurface = Null
Dim arrPoints, i, j
Dim fixState()
Dim idCopy
Dim uvCP, vecN, Ray
Dim arrX, blnComplete
idCopy = Rhino.CopyObject(idSurface)
arrPoints = Rhino.SurfacePoints(idCopy)
If IsNull(arrPoints) Then Exit Function
ReDim fixState(UBound(arrPoints))
For i = 0 To UBound(fixState)
fixState(i) = vbFalse
Next
Do
For i = 0 To UBound(arrPoints)
If Not fixState(i) Then
If i / GridSize = i \ GridSize And i <> 0 Then
fixState(i) = fixState(0)
arrPoints(i) = arrPoints(0)
ElseIf (i + 1) / GridSize = (i + 1) \ GridSize And i + 1 <> GridSize Then
fixState(i) = fixState(GridSize - 1)
arrPoints(i) = arrPoints(GridSize - 1)
Else
uvCP = Rhino.SurfaceClosestPoint(idCopy, arrPoints(i))
vecN = Rhino.SurfaceNormal(idCopy, uvCP)
If IsNull(vecN) Then vecN = Array(Array(0, 0, 0), Array(0, 0, 0))
If Rhino.Distance(array(vecN(0), vecN(1))) <> 0 Then
For j = 0 To 2
vecN(1)(j) = arrPoints(i)(j) + (vecN(1)(j) - vecN(0)(j))
vecN(0)(j) = arrPoints(i)(j)
Next
vecN = ResizeVector(vecN, stepSize)
Ray = Rhino.AddLine(vecN(0), vecN(1))
If Not IsNull(Ray) Then
For j = 0 To UBound(arrWalls)
arrX = Rhino.CurveSurfaceIntersection(Ray, arrWalls(j))
If IsArray(arrX) Then
'If Rhino.IsPointOnSurface(arrWalls(j), arrX(0,1)) Then
fixState(i) = vbTrue
If Rhino.Distance(vecN(0), vecN(1)) > Rhino.Distance(vecN(0), arrX(0, 1)) Then
vecN(1) = arrX(0, 1)
End If
'End If
End If
Next
Rhino.DeleteObject Ray
End If
arrPoints(i) = vecN(1)
Else
End If
End If
End If
Next
Rhino.DeleteObject idCopy
idCopy = Rhino.AddNurbsSurface(Rhino.SurfacePointCount(idSurface), _
arrPoints, _
Rhino.SurfaceKnots(idSurface)(0), _
Rhino.SurfaceKnots(idSurface)(1), _
Rhino.SurfaceDegree(idSurface), _
Rhino.SurfaceWeights(idSurface))
blnComplete = vbTrue
If Not fixState(i) Then blnComplete = vbFalse
Next
If blnComplete Then Exit Do
Loop
InflateSurface = idCopy
End Function
Function AddBalloon(arrStart, dblRadius, uvDensity)
AddBalloon = Null
Dim idSphere
idSphere = Rhino.AddSphere(arrStart, dblRadius)
If IsNull(idSphere) Then Exit Function
Rhino.UnselectAllObjects
Rhino.SelectObject idSphere
Rhino.Command "-_Rebuild _UPointCount=" & uvDensity & _
" _VPointCount=" & uvDensity & _
" _UDegree=3 _VDegree=3 _DeleteInput=Yes _CurrentLayer=Yes _ReTrim=No _Enter", vbFalse
If Not Rhino.IsObject(idSphere) Then Exit Function
AddBalloon = idSphere
End Function
Function AddGrowLines(O, R, S)
AddGrowLines = Null
Dim Hair(5)
Hair(0) = Rhino.AddLine(Array(O(0) + R, O(1), O(2)), Array(O(0) + R + S, O(1), O(2)))
Hair(1) = Rhino.AddLine(Array(O(0) - R, O(1), O(2)), Array(O(0) - R - S, O(1), O(2)))
Hair(2) = Rhino.AddLine(Array(O(0), O(1) + R, O(2)), Array(O(0), O(1) + R + S, O(2)))
Hair(3) = Rhino.AddLine(Array(O(0), O(1) - R, O(2)), Array(O(0), O(1) - R - S, O(2)))
Hair(4) = Rhino.AddLine(Array(O(0), O(1), O(2) + R), Array(O(0), O(1), O(2) + R + S))
Hair(5) = Rhino.AddLine(Array(O(0), O(1), O(2) - R), Array(O(0), O(1), O(2) - R - S))
AddGrowLines = Hair
End Function
Function ExtractWalls(idSurface)
If Rhino.IsSurface(idSurface) Then
ExtractWalls = Array(Rhino.CopyObject(idSurface))
Rhino.HideObjects ExtractWalls
Exit Function
Else
ExtractWalls = Rhino.ExplodePolySurfaces(idSurface, vbFalse)
Exit Function
End If
ExtractWalls = Null
End Function
Function ResizeVector(vecIn, newLength)
ResizeVector = vecIn
Dim vecOut(1)
vecOut(0) = Array(vecIn(0)(0), vecIn(0)(1), vecIn(0)(2))
vecOut(1) = Array((vecIn(0)(0) + (vecIn(1)(0) - vecIn(0)(0)) * newLength), _
(vecIn(0)(1) + (vecIn(1)(1) - vecIn(0)(1)) * newLength), _
(vecIn(0)(2) + (vecIn(1)(2) - vecIn(0)(2)) * newLength))
ResizeVector = vecOut
End Function
