How do I get the English version? Why does it install the Tsjech(?) version (without the standard toolbar)
Pracovní verze
(9.0.26111.12305, 2026-04-21)
Commercial
Pracovní verze
Commercial
I think they added all language support to the WIP installer file recently, maybe a bug crept in somewhere. Can you select English in Options>Appearance and restart Rhino? You may need to figure out what the equivalent of Options>Appearance is in in Czech…
Otherwise, you could also try going into Windows control panel>Programs and Features, find Rhino WIP in the list, right-click and choose “Change”, then “Modify” and then “Select Languages”, then check (Czech?) which boxes are checked. Check English if it is not checked already, and maybe uncheck Czech… ![]()
Actually I just did the above, here just checked German, French and English, but now I have all the languages in my list… Anyway, here is where to go in Czech:
My latest WIP installed in German and I was only able to change the Language to Englisch after the installatiin was done
This issue is on our list → RH-95013 Rhino starts in wrong language
Ok,thanks a lot for your help. I will try to change the settings in options.
Modify and re-installation and selecting English I already tried, that did not work.
