This mesh disappears when blocked
Check the attached file. When I block the mesh inside it, it disappears, I get an invisible block.
Maybe you can reproduce…
Hi Bogdan - here too - thanks. For now, RebuildMesh before blocking seems to sort it out… don’t know why, yet.
@Bogdan_Chipara - it looks like block display does not like the fact that the mesh has vertex colors. We’ll fix it…
Hm no that is not the whole story at least… still poking…
https://mcneel.myjetbrains.com/youtrack/issue/RH-40675
thanks,
RH-40675 should be fixed in the latest WIP. Please give it a try.
I opened the rhino file where I had the mesh and tried to block it. It disappears.
I imported the mesh in a new file and blocked it. It works fine. <-take this back. once i switch from wireframe to shaded, It disappears.
Tried to copy-paste the mesh from the rhino file where I had it, to a new file and block it. It disappears.
(6.0.17234.9201, 8/22/2017)
Yep, same here - looks like it broke again.
Thanks, sorry… the item has been re-opened.
Ok, let’s give this a try again. RH-40675 should be fixed in the latest RhinoWIP. Please give it a try (again!)
Thanks.
Fixed! Great!
