Is it just me, or thickness analysis doesn’t work on sub-D objects yet?
Thanks, you’re correct that command’s not supported yet for SubD. Filed as https://mcneel.myjetbrains.com/youtrack/issue/RH-56483
The request is set for v8 and you can track the progress on the link above. Hopefully it will be in the WIP sometime soon. I don’t know the specifics of why this is difficult but as a workaround I’d use ToNURBS on the SubD and then run the command on that.
Hi -
The issue is still on the list, so, no.
As you can see in the report, the target is currently at 8.x which means it’s not something that is - currently - on the list for the first release of Rhino 8 but something that can be added in a service release.
Another workaround is to use the Mesh command on the SubD and then use ThicknessAnalysis on that.
