The Thickness Analyses does not work here.
- command open the dialog
- After selecting an object the command window opens
- but it does not allow the Min value to be modified.
- trying with the default values: the command run until it gives up at 2%. that happens on a mesh
5)trying it on a simple NURBS object simply crushed rhino.
- I’m told that the command does work on Windows, but that it’s buggy and tends to fail.
Having a good thickness analyses can be crucial when the goal is 3D printing.
Especially for organic forms jewellery where one has to try and minimise the volume in order to save on gold costs [@ nearly 50$/gram that’s really important]
PS. see also in here: Is there a way to analyse a [dens] mesh for 3D printing compatibility?
Thanks a lot
Akash
