Thickening is missing when exporting
Create a surface with thickening:
2026-09-11 thikening.3dm (77.0 KB)
export it (keeping Rhino8 format)
2026-09-11 thikening exported.3dm (63.5 KB)
Thickening is lost !
Rhino Version 8 SR34
Thickening is a rendered effect only. To produce actual geometry for the thickened surfaces, Shell or OffsetSrf can be used.
No, when you export some surfaces, keeping the Rhino format, the properties of the surfaces must be kept ; otherwise you can no more collaborate inside a Rhino team !
My confusion is about “export”. You did not export, you saved as a Rhino 3DM?
I just tested thickening in SR34. When I add thickening and save the Rhino file, the thickening check box is checked when I open the file. I’m not sure where the thickening is lost when you save the file.
Save as is related to all your Rhino file. When you collaborate, you usually just need to send some objects, not the all file with all it’s environment. You select the objects and export the selection (keeping Rhino format).
Thickening is not lost here when I Export to a Rhino file.
Are you picking “export geometry only” or something?
Your sample file with thickening doesn’t actually show any applied.
For me, the thickening is not lost when I choose “export selected” and save to a Rhino 3DM. Can you make a screen recording to show your export process?
Found out,
To reduce file size and avoid unnecessary data, I did not checked “save plugin data”.
I didn’t know that plugin data was also related to Rhino standard features.
Many Rhino commands are implemented as “plugins.”
