How do you take a lofted surface that’s open on ends and along it with the lower part a recurve on itself and add thickness, I need 1.30mm & using surface extrude hasn’t worked & other tries.
So, can use advice, continuing to look, thx…
Try Surface offset with solid option ticked in the command line.
Got it thanks, lofting is very nice.
