Column with algae.3dm (15.5 MB)
Hi, does anyone know how I can thicken this model so I can 3d printed with resin or powder print? I need at least 1mm of thickness to the inside but cant make it work
Hello- in theory you should be able to Join all of these parts into one and with a bit of luck, OffsetSrf. However, you file tolerance is 1 unit which makes a mess of joining as the edges are less than one unit apart - if you set the tolerance to .01, there is a chance it could work but if all the parts are made a 1 unit tolerance, there could be problems.
See - Understanding Tolerances [McNeel Wiki]
Thanks Pascal, yeah I tried Joining the geometry and then trying to offesetsrf with diferrent tolerances but doesn’t work
