These styles of windows and doors disappear in plan view
windows and doors disappear.3dm (4.0 MB)
Hi @miguelayora3 this happens because there is no component in this object set to be displayed in plan view. If you edit the style, (right click on the door style name > Edit…), you will be able to assign the components to the plan representation.
This is actually a change in relation to VisualARQ 2. Now you have more control about which components are displayed in plan view, in model view, or both.
I activate everything in Plan and I still have the same problem
Hi @miguelayora3,
I am activating it and it works in my case. Is this happening to you with the three styles? Please, could you send me the file after activating it? Just in case we are missing something.
Also, do you have any other plug-ins installed in Rhino? If so, please disable them from the Rhino options and restart Rhino to check if this fixes the problem.
door VA.3dm (8.4 MB)
This is happening with the door style, the others styles are working, please help me with this problem.
Thank you.
Hi @miguelayora3,
The door style in that doesn’t have the plan option enabled. If I activate it, it works in my case. Are you following this process in the same way or are you doing something different? Please, let me know if you are doing something different so that I can reproduce it:
DOOR VA
@miguelayora3 you need to run the vaStyleProperties command on that object in order to edit its style. In your video you are running the vaProperties instead, which is the dialog to edit the object properties only.
