Hi everyone, I’m new to Grasshopper. I’m working on a kinetic facade which uses thermobimetal that bends when respond to temperature fluctuations. However, I only know how to make the “petals” rotate around an axis instead of bend & deform following an arc along the midpoint of the “petal”. Can anyone help me with this? I have attached the grasshopper file and an image on the desired outcome of the kinetic facade. Thank you.
Hi, @Sean_Ng–and welcome to the Rhino Forums! I’m interested in this idea and took a look at your file. When I have more time, I’ll test out what I asked ChatGPT, but you and others are welcome to read what it provided as a possible path to a solution. ChatGPT - Curl Surface with Slider
