Hi
There is a bug when we execute the MergeFaces command that we want to verify that the vertices remain.
Hi
I personally do not see this as a bug. When you merge faces on a corner your end points become internal. Their influence on the surface is different, hence the rounding of the corner.
Hi, Mehran,
To date, we have never intentionally permitted a mesh “ngon” to have unwelded vertices and MergeFaces is working as designed. Anything interior to a merged face on an ON_Mesh becomes “welded” so the “ngon” will shade smoothly. The same is true for using MergeFaces on a SubD object.
Is there some task or workflow that would be easier if ordinary mesh ngons had interior unwelded vertices?
Hi @dalelear
It would be much better if the Merge Faces command would work in a mesh like subd because it is much better in subd and help ease the modeling.It still depends on you how to correct it
Thanks
