There are several migrate(Rhino5 to Rhino6) problems
There are several migrate(Rhino5 to Rhino6) problems.
Is there document of migration details?
  1. unit type are undefined:
    SP173110-12
  2. How to get rhino_doc_sn when I call “RunScript()” function?
    SP173110-13
  3. class “CRhinoLayer” has no member “LayerName”
    SP173110-14
  4. class “ON_Xform” has no member “Zero”
    SP173110-15
Vaker
Hi @Vaker
Please review the following:
http://developer.rhino3d.com/guides/cpp/whats-new/
1.) unit type are undefined:
switch (Unit)
case ON::LengthUnitSystem::None:
  break;
case ON::LengthUnitSystem::Millimeters:
  break;
// Etc...
default:
  break;
2.) How to get rhino_doc_sn when I call “RunScript()” function?
CRhinoCommand::result CCommandTes6::RunCommand(const CRhinoCommandContext& context)
  const unsigned int rhino_doc_sn = context.m_doc.RuntimeSerialNumber();
  // TODO...
3.) class “CRhinoLayer” has no member “LayerName”
ON_wString layer_name = obj->ObjectLayer().Name();
4.) class “ON_Xform” has no member “Zero”
ON_Xform xform = ON_Xform::ZeroTransformation;
– Dale
Hi @dale,
Thanks for your help.
I still have build error as below:
SP173110-17
Vaker
Use ON_Layer::SetName.
– Dale
Hi @dale,
How to clear all data in document?
“RhinoApp().ActiveDoc()->Destroy();” in Rhino5
The function “Destroy()” become a private function.
How to get (or create) CRhinoCacheHandle when using CRhinoDisplayPipeline::DrawShadedBrep()?
I wnat to get ON_ClippingRegion::m_xform in Rhino5.
Can I use ON_ClippingRegion::ObjectToClipTransformation() to get it in Rhino6?
Vaker
Hi @Vaker,
Wow, I think you’re the only developer whose was brave enough to call CRhinoDoc::Destroy. Is there any reason you cannot just script the New command?
Why do you need or want to do this?
Yes.
– Dale
