When I explode a leader in Rhino 7.4, the Explode command makes new objects, but it does not delete the leader.
I cannot move the leader, I cannot delete it, and I cannot edit it. When I turn on control points, they cannot be moved with the Gumball. I cannot make any changes in the text either.
I have found the same bugs in DimRadius and DimOrdinate commands - these dimension objects cannot be deleted. I did not check other dimension commands.
I have just found the cause of this bug! I have always tested this bug in the same file: junk7 SubDs.3dm (542.7 KB)
When I tested this bug in new, empty file made without template, the bug disappeared.
Even in this file, if you explode the leader, it is deleted. But the leader’s curve has an invalid domain. So when exploded, Rhino deems the curve as junk and tosses it.
I don’t suppose you recall how you created this? Was it made with a version of Rhino prior to 7?
I disagree. Exploding the leader does not explode it. It merely duplicates some of its parts shown in the bottom half of the following screenshot.
It was made by Robert McNeel & Associates as example of SubDs in Rhino 6. I used it to play with new commands for several years and I changed it a little.
