The way the number of points decreases along the Z-axis
I want to create a grid using Grasshopper on a “3D surface modelled in Rhinoceros”.
I want that grid to be finer with a smaller Z-axis (bottom) and larger with a larger Z-axis (top).
I am a beginner. It would be helpful if you could be more specific.
Grasshopper: 1.0.0007
Rhinoceros: 7.30.23163.13002
Please post at least a Rhino file with your surface or a Grasshopper file of what you have so far.
A sketch of what you want to achieve would also clarify things a little more than your explanation.
To learn more about lists and data trees, you can study the Modelab primer.
https://modelab.gitbooks.io/grasshopper-primer/content/1-foundations/1-foundations.html
Thanks for the replies.
The files are these.
gh_test.3dm (3.4 MB)
1017flame.gh (20.2 KB)
Not based on your file, but is this the type of grid you are looking for?
Thanks, basically yes.
I just want to do this with a 3D surface made in Rhino.
Basicly, you need to determine the U and V coordinates on the surface:
  • using graphmapper you determine the irregular ones
  • using range you determine the regular ones.
I used python (propably incorrectly, but well it works) just to combine these two values to make it look like the output from MD Slider → you can use native gh components for that but it’s wierdly complicated
somehowItWorks.gh (18.4 KB)
as far as i understood your sketchs you want to creat a diamond pattern rigth?
i found a solution if you treat´the sides seperatly
1017flame.gh (21.7 KB)
found it in the primer
http://grasshopperprimer.com/en/1-foundations/1-5/4_working-with-data-trees.html
EDIT:
found a solution for the whole surface:
i set the graphmappers range to 0.5 “mirrored” the results and merges them.
This script is based on the surface UV so i you are having a problem on other surfaces you migth need to swap UV in rhino with the direction command - hope this helps.
1017flame.gh (53.1 KB)
