My wish would just be that Rhino 6 could handle large dwgs fast and reading Autocad Layouts and dimensions correctly.
Most of the material you get from clients and contractors are 2d dwg plans and sometimes when I import them in Rhino I cannot even clean them up, because it slows down the software immensly.
Rhino 5, Blender (converted to dxf), handle them much, much better. I use a macbook pro 15" 2017
Hi Ells,
This makes complete sense.
I have checked and this issue has not been logged.
I added to the tracking system Open/Import DWG with Xref as a Linked Block RH-57627. As soon as I test a fix, I will let you know. Thanks again for pointing this out.
