The trouble with scribbles
It is often the case that large window selections of objects on the canvas leaves a few scribbles behind :
When gone un-noticed, this leaves quite a mess after a displacement of the selected objects…
I changed the title.
Let’s see who will be the first to pick-up the reference…
Also, you can’t (or at least I can’t) Copy and Move them. I have to keep going to the menu to pull down a new one.
When I need to move multiple scribbles, I found out that I must also select a “normal” component or a panel, and drag the whole bunch with the first click on that object.
That’s another problem with scribbles.
(No one’s got the pun ? Really ?)
If you’re referring to the “Trouble with Tribbles”, then maybe that’s the problem.
I stand corrected !
:slight_smile:
