Did I do something wrong?
test_squisher.gh (153.9 KB)
Thank you for your feedback. It seems this is an error with the Squish function. You can use the Mesh component to fix this issue. I will log this problem to our development engineers later.
It has been logged to our development engineers.
https://mcneel.myjetbrains.com/youtrack/issue/RH-89644/Squish-unable-to-obtain-the-correct-result
Thank you sincerely!
@zhangvip0755 There’s nothing I can fix here, this is a problem in the “Squisher” Grasshopper plugin that you are using. I suggest you take this to the developer of the plugin. They have listed this address as a contact point on food4rhino: squisher@lharchi.com
