The reason of Rhino8 for Mac can not use Lunchbox!
Rhino8由于可以调用Metal,极大的提高了Mac版本rhino的性能,但是目前,部分Grasshopper插件,不支持原生Rhino8,这怎么解决呢,例如Lunchbox这款插件。经过我的反复折腾和研究,终于知道了问题所在,需要在访达,应用程序,找到Rhino8,右键,显示简介,勾选以Rossta打开,这样就可以和7一样,安装任意插件了。虽然这样,Rhino是经过转翻才运营的,但是也可以调用Metal,经过我的实际测试,即使是转翻过后的8,只要调用了Metal,速度就会大幅度提升,运行大模型也比较流畅。
Rhino8 due to the ability to call Metal, greatly improving the performance of the Mac version of rhino, but at present, some Grasshopper plug-ins, does not support the native Rhino8, which how to solve it, such as Lunchbox this plug-in. After my repeated tossing and research, finally know the problem, you need to visit Da, applications, find Rhino8, right-click, show profile, check to Rossta open, so that you can be the same as 7, install any plug-in. Although this, Rhino is after the flip before operation, but also can call Metal, after my actual test, even after the flip after the 8, as long as the call Metal, the speed will be substantially increased, running a large model is also more fluent.
Hi -
Some plug-ins have native assemblies that are compiled for Intel x64 only.
As you say, you can open Rhino 8 using Rosetta to get those working.
Running this way, Rhino’s performance is expected to be on par with running Rhino 7 on that machine, but there should be a performance hit over running Rhino 8 natively on Apple Silicon.
@archinate1 Do you know what is going on here? Do you plan to update Lunchbox to use universal binaries for native mac comparability?
