The phantom four Points
Around the wall of a cyliner, I’m seeking to generate six points (only) via intersecting six lines that radiate from the center axis (red box).
However, an extra four points appear that are unwanted.
These match up with lines at the cylinder base that appear when the cylinder is uncapped (orange box). It appears the issue is related somehow to the capping aspect. However again, those extra four points appear whether or not the cylinder is capped. I’ve attached a Gh file.
Any thoughts please?!
The Phantom Four Points.gh (10.3 KB)
This is sort of a common word misinterpretation, I stumbled upon this in past too.
In Grasshopper and Rhinocommon, a Line is generated as a “Line segment” , finite, with a start and an end point.
But then, it is often used as an infinite line (both extremities).. expecially with intersections.
Brep | Line intersection component is treating your lines as a “geometrically infinite line”, thus giving you two intersection points for each line.
Use Brep | Curve instead.
When you use your line with a component requiring a curve, the line will be treated as a “line segment” , finite.
Riccardo, thank you; that works for cylinders both capped and uncapped.
