sayyin
(Sayyin94)
December 2, 2020, 5:37pm
1
‘The paste command failed to begin writing to temporary file’ is shown when I tried to copy from one file and paste on another file. Hence, nothing was pasted successfully. This does not usually happen and it happens all of a sudden when no settings have been changed. I wonder if this is one of Rhino’s bug.
I have tried to restart and things went back to normal. However, after half an hour, the similar problem occurs. Appreciate if anyone can enlighten me please. Thanks.
pascal
(Pascal Golay)
December 2, 2020, 6:24pm
3
Hello - please run SystemInfo
in Rhino and post the results.
sayyin
(Sayyin94)
December 3, 2020, 3:35am
5
Rhino 6 SR31 2020-11-10 (Rhino 6, 6.31.20315.17001, Git hash:master @ ff08c426b1ef7d3a1c50a01e5e87220a68a9f815)
License type: Educational, build 2020-11-10
License details: Cloud Zoo. In use by: Chuah Say Yin ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: LAPTOP-NBVIVFRN
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 7-5-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 451.67
Secondary graphics devices.
Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-19-2018 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-5-2020
Driver Version: 27.21.14.5167
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.31.20315.17001
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.31.20315.17001
C:\Users\ASUS-PC\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Users\ASUS-PC\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2019.11.5.949\Lumion\Rhino 6.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.31.20315.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.31.20315.17001
C:\Users\ASUS-PC\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\SectionTools (fbdb1d7f-8cfb-42c1-9858-87cb6315932c)\2019.7.29.584\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 6\Plug-ins\NamedPositions.rhp “Named Position”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
pascal
(Pascal Golay)
December 3, 2020, 3:39am
6
Hello - please uncheck ‘Enabled’ for the two plug-ins above, in Options > PlugIns page and then close and restart Rhino - does this behave any better?
sayyin
(Sayyin94)
December 3, 2020, 4:16am
7
Thanks for your reply.
At the moment there is no problem with the copy and paste command because the problems goes away for awhile after I restart Rhino. I will try your suggestion if the problem occurs again and will let you know if it works.
Thank you.
sayyin
(Sayyin94)
December 8, 2020, 12:37pm
8
it behaves better and the copy and paste error seldom appear after I turn off the plugins as suggested. However, the error appear again after I turn my V-ray on.
Appreciate if Rhino can solve this problem as I really need my plugin to be turned on while working on my model. Thanks in advance.
pascal
(Pascal Golay)
December 8, 2020, 2:46pm
9
Hello - please also contact VRay technical support -
