The Move command
I found out that in the Move command, the option for Normal is redundant (it doesn’t do anything at all). What is the difference between the Normal and Vertical options? I think the Move command should be reviewed.
Moving things normal in relation to a point on a curve or surface is essential.
I use it all the time.
