The Mouse Selecting Failed after baking Geometry
I’m using the GH plugin Elefront to bake out geometries. It happened several times that after baking, mouse clicks would fail to either select or open the function menu of node. The whole GH is paralyzed in that way. I’m only be able to fix it by reopening Revit. BUT, Revit file are usually quite big… doing so will be very time comsuming.
Does anyone else had the same issue? Anyone knows how to fix it without reopening Revit?
