The long standing bug - dimensioning circles in the Detail View!
See the video. This bug is causing many problems in the shop!!
Video_2022-01-17_164408.7z (13.3 MB)
Uploading a video would make more sense than a compressed file every person has to download to view.
Hi -
Very rarely, a video alone will provide enough information for us to be able to check the issue.
Please run the Rhino SystemInfo command and copy-paste the result here.
In a quick test here, I was not able to reproduce this issue. If you notice any steps that are crucial for this behavior to take place, please describe those steps in as much detail as you can.
Really don’t know what else to describe - on the video is visible that I’m creating a circle, dimensioning it in the model space, then creating a new layout with one detail view, then dimensioning the circle in the layout, then activate the detail view, then zooming an panning in the activated detail view, then deactivate the detail view and the dimension of the circle in the paper space is changing and showing the wrong value.
Rhino 7 SR14 2022-1-10 (Rhino 7, 7.14.22010.17001, Git hash:master @ d8a2d020be8cb487bfc091316ef32170cfc7eddb)
License type: Commercial, build 2022-01-10
License details: Stand-Alone
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 15Gb)
Primary display and OpenGL: NVIDIA GeForce GTX 1650 Ti (NVidia) Memory: 4GB, Driver date: 12-29-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.09
> Integrated accelerated graphics device with 1 adapter port(s)
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 4-23-2021 (M-D-Y).
> Integrated accelerated graphics device with 3 adapter port(s)
- This device is not being used
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-29-2021
Driver Version: 30.0.15.1109
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.14.22010.17001
I
Thanks! I’ll get this on the list.
Filed as RH-67054: Annotation: Zooming in detail breaks radius and diameter dimensions on arcs
RH-67054 is fixed in Rhino 7 Service Release 16 Release Candidate
Works fine now!
Thanks Brian!
