When I imported the x_t file to other software, I found the CAD file is distorted.
Do you know why?
Thanks,
graph in Rhino
graph in other software.
John
Do you know why?
Thanks,
graph in Rhino
John
Hi John,
It would be best to post both the rhino file as well as the x-t file. With those at hand it might be easier for McNeel to track down the problem. You could also upload your file to McNeel Support via this site: http://www.rhino3d.com/upload
Did you try to export to the various different Parasolid export settings? Do they all show this incorrect import?
-Willem
Hi John,
some solid modelers have problems with importing closed (revolved) surfaces. You may try to to split the closed surface(s) into multiple surfaces, before you export the x_t file. With your geometry selected in Rhino, run the command _TestSplitClosed.
c.
