The Explode command and the UnjoinEdge command
Have the Explode command already,Is it necessary to have the UnjoinEdge command?
2021-07-10T15_35_43
2021-07-10T15_36_04
Yes. The two do different things. Explode explodes (unjoins) the entire object, UnjoinEdge allows you to select edges individually to unjoin while leaving the rest joined.
If I explode the entire object, select parts that I want to keep then jion them, is that same effect with the JoinEdge command?
Explode works on an entire object. Join can work on a collection of preselected objects or with post-selection, it can join things one-by-one. In both cases you are selecting objects - curves or surfaces/polysurfaces.
JoinEdge and its inverse UnjoinEdge work on individual edges of surface/polysurface objects, not the entire object.
Thank you.
