We talk about materials used for mechanical components in sports cars, like the one posted by @CADARTZ above. 3d printed 6061 can never reach the strength of billet 6061-T651. It’s close to cast aluminum. Not to mention the very high risk of porosity and cracks over time, along with the strength being dependable on the 3d printing orientation on the bed. Billet 6061-T651 is equally strong in any direction, being a highly predictable material, making it the preferred choice for mechanical components in cars and other machines.
There are rare exceptions such like 3d printed 6061-RAM2, which requires an expensive and extensive post-treatment and it’s never guaranteed to reach the theoretical maximum strength in all directions due to the dependability of the 3d printing orientation.
Oh hell naw…
I’ve worked with cast aluminum, every other pieces we had to throw away after cnc machined because of porosity and cracks
Not to mention how fragile it is to get dented.
“An easy example. They use the same diameter for the “rods” of parts where one side is pulled out and the other is pushed against. What’s worse, some of their parts have noticeably thinner pulling rods than pushing ones.
People with real experience know that the pulling rod must be thicker due to the effective tensile strength (ability to take pulling stress) being far lower than the compressive strength.:”
Don’t you mean the other way around? A steel member under axial tension can be thinner than a steel member under compression, as the member under compression needs to resist buckling forces.
Presumably the metal RP process discussed above is SLS? Anyone have experience with EBM parts? I don’t directly but the process looks interesting and they are using parts in production - aerospace, medical etc.
This one is interesting - local company that has been developing rapid casting process using microwave amongst other stuff. I believe they have the porosity to a negligible level now.
Short components with farm-like structure (like those used in sports car suspension) require thicker pulling rods than the compression ones, because they are short enough to withstand sideways bending during a longitudinal compression. This is possible thanks to the small ratio between length and diameter.
However, if we talk about some very long structure, such like 2 meters long, then it’s the other way around: pulling rods can be thinnner, but the compression ones must be substantially thicker due to the extremely high ratio between length and diameter.
Ok - didn’t realise it was all car specific discussion. I was thinking of a spoke on a bike wheel. Can take quite a load in tension but then it is like trying to support the same load with a wet noodle in compression. But diameter to length ratio is large.
General rule-of-thumb is Length/dia > 30 is where buckling consideration triumphs compression strength. Of course that’s kind of theoretical because it assumes absolutely no torque applied at the ends.
A ratio of 10:1 (length versus diameter) is considered the maximum safe ratio for use with 6061-T6 aluminum parts that are designed to take extreme pushing forces, like the bellcranks (rocker arms) of the push-rod car suspension type.
One common mistake of those who rely on automatic generative design is the use of long rods whose middle portion is noticeably thinner than its both ends. Like a thin waistline. Those rods are prone to bending under longitudinal pushing forces way sooner than a rod with the same mass whose diameter is consistent along the whole length. Ideally, a rod that’s meant to take pushing forces should be thicker in the middle, especially if it’s close to (or longer than) the 10:1 ratio.
Not sure how topological optimalisation and metal printing is related to AI. However in llm apocalypse I am leaning on @andy6 side, which changed and further change or entirely wipe most of digital work we processing here.
Agentic llms are such a powerful tool. Not only grokbot agents could talk in between.
I hope that rhino will survive this, as I love the tool and philosophy around it. Grasshopper learned me to think in systems, very usefull, thank you.
yeah it’s crazy cause there was a crowd sourced dude that was coming out with economical metal printing but I think form labs gobbled it up.
obviously if it ever becomes affordable I’m definitely going to buy the tech, but the main thing I failed to mention above, was the ‘shrinkage’. I edited my message late.
but the shrinkage is like 30%. and that’s really bad for certain geometries.
so the tech would have to be laser based and magically fully fuse the molecules with very little shrinkage for super cheap – then I’m all in on that.
until then, I’ll have to build an electrolysis lab and maybe a magnetron for plasma vapor deposition or something lol.
Digging myself into this there are certain design rules you must follow when designing for it, Just alot of info to consider even at the cad phase
here is the impression ive gotten so far with AM in general, whether it is metal or MJF nylon every machine needs to be calibrated to your specific needs there is alot of micro adjustments and tweaking that takes months before it produces with desired results, no machine is alike.
There is one thing that someone said at the start of my studies: “-Every machine is its own little character” which has shown to be true in this field.
I might’ve highballed it a bit to 30%, but I’m imagining the metal process of all that post baking and fusing of all the metal dust lol. but lasers that do that in real time would be sweet
probably less shrinkage then.
also I noticed you sent desktopmetal link, yeah I agree they’re pretty much the best in terms of economics etc still. they seem to be dominating. but still lot’s o’ money ![]()
tungsten carbide cobalt spit out my coffee lol omgawh
I think this discussion might need to be split in two because there was high divergence in the subject
my tin foil hat is on…but ![]()
I think AI is abused as an extortion tool to keep wages down and for the unions to be more lenient with the rules and demands.
The perfect lobbyist.
Unions? I asked Grok and it said they were a deprecated feature from the 20th century. Removed in v2.0 for “performance reasons”. ![]()
Well he ain’t wrong there I had my fair share troubles with them
If only they allowed me to work a bit more in the past but nooooooooooo “you worked to much nag nag nag”
They probably made sense before…![]()
