I’ve tried on 3 different models, always with an error.
Creates a new page with 2 views. Both views are set to display mod Patent.
(Patent Mode changed to Patent Print mode) according to http://wiki.mcneel.com/rhino/advanceddisplay
(different for the monitor display and printing) OK
Ctr + P print preview, OK
print to PDF OK
The print to jpg (png, and …) Always error – not
applicable to …
It goes out (not from PDF to jpg via Photoshop … it can do too
Printing and display are closely connected so my first guess is to check the graphics card driver. Look in Rhino Options> Display>View>OpenGL and post a screenshot here or if the driver is old, look for an update from the GPU manufacturer to see if that helps. PDF printing uses a PDF print driver on your system which may be why that is working better. The Print dialog will list the PDF print drivers installed.
Printing to a lossless format like PNG or BMP should work. JPG is lossy though and particularly so over areas of gradient so for the hatch shadows in this display mode, I’d avoid using it.
Thanks for the file and this report. It appears to be a bug with a custom technical mode and more than one detail in a layout. I filed it as http://mcneel.myjetbrains.com/youtrack/issue/RH-29421 for our developers to look into.
