The curve formed by the intersection of two surfaces is missing
The curve formed by the intersection of two surfaces is missing(图1), but the intersection curve is complete in AutoCAD(图2).
图1
图2
How should this be handled?
It is very difficult to help without a .3dm file with the objects. You can upload a file by dragging it to where you type a post, or by clicking on the vertical arrow icon above where you type a post.
How are you obtaining the intersection curves? Are you using the intersect command?
It’s just two intersecting conical surfaces, using the _Intersect command.
Hi -
That works just fine here.
I tried creating two surfaces and Intersection resulted in two complete curves. Without a .3dm file with your objects it is impossible to determine what is different between your objects and my objects.
Also how are you creating the intersection curve?
Okay, the file I uploaded.
1.3dm (143.3 KB)
@wim Using Intesect command I can reproduce the missing portions of the intersection curves in Rhino 7 (used by @CTQCTQ), Rhino 8 and Rhino 9 Beta. No cause is obvious to me. This may be an example of a problem intersecting rational surfaces.
Is it not working in Rhino 7?
It seems to be a problem with the model scale. After scaling it down from the original size, the intersecting curves appear more complete.
Hi -
Thanks. I’ve put this on the list to get fixed: RH-98829 SSI: Failure on Two Conical Srfs
Okay.
Interestingly it works in V3 and V4.
It seems that I have solved it with Ai. The intersection lines of these two surfaces are complete.
