The color mismatch between the original surface and the flattened surface
I assigned ‘planar mapping axes’ to these font surfaces and applied color textures. After using the Squish command to flatten them, I found that the colors of the flattened surfaces did not match the original surfaces. This was not an issue in Rhino 5, but it occurs in Rhino 7 and Rhino 8. What could be the reason for this, and how can it be resolved? Thank you
This item reads like you were going to attach an example .3dm, but it’s not there.
Hold on, I’ve been uploading for an hour and a half now.
How big is the file? if it’s over 10Mb, make sure it’s zipped. If it’s too big, upload it to something like WeTransfer and post a link.
Or, something/someone is blocking your upload for some reason.
