tom33
(Ye lin a)
March 5, 2025, 2:07am
1
Here is my code and the result. I gave the button an image attribute and a path. The code does not show an error, but the button does not show an image
#prvb .Imager = ed.Bitmap(image_path)
import scriptcontext as sc
import Rhino
from Rhino.UI import RhinoEtoApp, EtoExtensions
import Eto.Forms as ef
import Eto.Drawing as ed
image_path = r"J:\assets\SLOGO\JCAD\curve.png"
#RhinoEtoApp.MainWindowForDocument(sc.doc)
#SampleTransparentEtoForm(Eto.Forms.Form):
parent = RhinoEtoApp.MainWindowForDocument(sc.doc)
table_layout = ef.TableLayout()
table_layout.Padding = ed.Padding(8)
table_layout.Spacing = ed.Size(4, 4)
ceshi_label = ef.Label()
ceshi_label.Text = "测试:"
sil_0 = ef.Slider()
sil_0.Text = ""
sil_0.MaxValue = 10
sil_0.MinValue = 0
sil_0.Value = 3
m_numeric_updown = ef.NumericUpDown()
m_numeric_updown.DecimalPlaces = 2
m_numeric_updown.Increment = 1
m_numeric_updown.MaxValue = 10.0
m_numeric_updown.MinValue = 0.0
m_numeric_updown.Value = 3.0
prvb = ef.Button()
prvb.Imager = ed.Bitmap(image_path)
#prvb.Text = "测试"
m_numeric_updown.ValueBinding.Bind(sil_0, "Value", ef.DualBindingMode.TwoWay)
row_0 = ef.TableRow()
row_0.Cells.Add(ef.TableCell(sil_0))
row_0.Cells.Add(ef.TableCell(m_numeric_updown))
row_1 = ef.TableRow()
row_1.Cells.Add(ef.TableCell(prvb))
#row_1.Cells.Add(ef.TableCell(ceshi_label))
#row_N = ef.TableRow()
#row_N.Cells.Add(ef.TableCell(controls))
table_layout.Rows.Add(row_0)
table_layout.Rows.Add(row_1)
#table_layout.Rows.Add(row_N)
def on_print(s, e):
#object_id = rs.GetObject("测试")
se = sil_0.Value
#ceshi_label.Text = rs.ObjectName(object_id, name=None)
print(se)
prvb.Click += on_print
dialog = ef.Dialog()
dialog.Content = table_layout
#dialog.Width = 200
#dialog.Height =300
dialog.Resizable = True
dialog.Title = "测试"
EtoExtensions.ShowSemiModal(dialog, sc.doc, parent)
tom33
(Ye lin a)
March 5, 2025, 2:11am
2
Okay, so I’ll use public Image Image {get; set; } This method works
tom33
(Ye lin a)
March 5, 2025, 2:23am
3
This is my current code and running results, I ran into a small issue, the width of the button inside the layer can not be limited. I used prvb.Height = prvb_size = 40
prvb.Width = prvb_size
But I only reduced the size of the image, the size of the actual control is out of my control
import Rhino
sil_0 = ef.Slider()
sil_0.Text = ""
sil_0.MaxValue = 10
sil_0.MinValue = 0
sil_0.Value = 3
prvb = ef.Button()
prvb.Image = ed.Bitmap(image_path)
#prvb.Text = "测试"
def on_print(s, e):
se = sil_0.Value
print(se)
#dialog.Width = 200
#dialog.Height =300
dialog.Title = "测试"
Hi @tom33 ,
This is because you are using a Table Layout so the button fills the cell size.
You could instead use DynamicLayout and put A and B in a row and then C and D in the next row.
Or keep your TableLayout but in C cell add a PixelLayout() and then add the C button control to the PixelLayout which will let you have more nuanced control over the button size and position.
Probably another/better way with TableLayouts but I haven’t used TableLayouts much so hopefully another user who has can chime in on that…
Hope that helps for now!
tom33
(Ye lin a)
March 6, 2025, 12:59pm
5
Thank you very much, Sir. It is useful to me. Thank you for your inspiration to me
