This pic Show my Problem Better!
This is the Pack scene!
No attachment here ā¦
You need to upload the file and attach it. In the post editing window click on the icon with and up arrow
Sorry, I am trying to Upload that but it take many times to upload!!!
my pack scene file is 8.8 mb!!
I am trying so!
Try uploading to Dropbox?
Sent from my BlackBerry Z30From: ft mottaghiSent: Saturday, February 27, 2016 10:27 AMTo: thebowman@shaw.caReply To: McNeel ForumSubject: [McNeel Forum] [Rhino for Windows] Textures not rendering on blocks (Vray)
February 27
I am trying so!
Visit Topic or reply to this email to respond
In Reply To
juancarrerasFebruary 27No attachment here ā¦ You need to upload the file and attach it. In the post editing window click on the icon with and up arrow
Could we redefine a new texture or Mapping for a Block from our main file not from our Block file???
Looking at the file now. I see a couple of problems. Iāll report later.
Thanks Juan
See attached. Iām sending the scene with only the concrete block with the problem. Everything else was irrelevant.
A few problems:
1.-
You had the vray sun on but in the environment, the skylight had no sun
selected and the background had the wrong sun selected. They should be
both with Sun1 (the vray sun) active. That was giving strange
lighting.
2.- You had the block nested with itself although Iām not sure whether this would matter in this case.
3.- The main problem in my opinion is that the material of the concrete shape (concrete_tiled) had the bump map with type ābumpā but the texture is a norml map so have best results with the bump type āNormal map
(object space)ā. This will give you smoother definition. Also I inverted the map in the texture manipulation so that the concrete seams and cofferdam anchors point inwards.
I made a second block definition with better mapping on each side but Iām not sure if thatās what you want.
I reccomend that you make the Rhino blocks with material by parent when you define it. Then after you insert it, you can always freely assign a different material if you change your mind whether with the layer or directly to the object. The 2 blocks are now defined like that.
I hope this helps
Cheers
villa savoye_edited.3dm (796.0 KB)
Great
I will change my setting as you mentioned.
Thanks a lot Juan
I have SR12 and this is still a problem for meā¦
Olofj
Can you send an example ?
Olofj
Iām not sure if I follow your problem.
You sent me a block defined with material āby parentā inserted in āParent layerā which behaves correctly.
Also, if the material of the parent layer is a textured material, the texture displays and renders correctly. (see attached). I have also SR12.
What are you after exactly ?
example-byparent.zip (383.7 KB)
Hi Juan,
ok, I understand the confusion. The problem occurs in my vray. When I have rendered on in the view port it behavesā¦ but when i render with vray it shows block base layerā¦ which version of vray do you have?
Ok! Just needed to update my vray to latest version and it worked! Thanks for your help
oh good, Iām glad itās working for you.
