Hi there,
I am having problems with assigning textures to my file. When creating materials (not textures), the pull down will prompt you to assign to object selected but not so with textures. There is no ability to assign a texture to an object. I used to be able to drag and drop, but that will no longer work. I am having problems with the floor as a texture where I can control the mapping. Is there a method I can use.
I had to brake up my original file because it was too large. I hope there is enough there to work with.
TEXTURE TEST.3dm (10.7 MB)
Thank you as always for your help.
