Hey guys,
In Rhino 6 I’ve created Textured display style out Shaded, changing display material to Rendering material (using V-Ray). It rarely works, on most objects it doesn’t show up correctly. Is it a known bug in Rhino 6? I’m talking about large scale, approx. 3 buildings.
Btw other question, if Rhino viewport is choppy and at the same time my RTX 2070 and i7 8700k usage is only around 50%, could it signal something’s not right? I would expect the GPU to be at 100% while it has problem keeping up with the viewport movement.
Although it doesn’t help, it seems to be caused by V-Ray. If I replace the layer material by a Rhino mat, this one object’s mapping shows up. Not if I replace it by a V-Ray mat.
Will look it. Don’t think it has been reported yet, as far as I can remember.
As for the viewport “choppiness” you mentioned in the first post, does it occur only with specific projects? Is it reproducible while V-Ray is not the active renderer? If you can share any additional info, please email us at support@chaosgroup.com
