I need the texture lays only on front side of the box. On another side of the same box I need to match other texture. Explain please in detail the method to do it.
This is a clunky, limited, unsupported (you donât get to complain) , undocumented command
you donât get to complain.
It probably doesnât work on that box of yours because you need to select a surface of a polysurface. The box is likely an extrusion and as such doesnât have any âsurfacesâ (by that limited definition). Convert the box to a polysurface by using the ConvertExtrusion command and I think you will have more luck.
