Texture not displaying
Hello!
I’m having issues with procedural textures displaying in the viewport properly in Rhino WIP and 8. In this example, the texture only shows when created in ‘surface’ mapping mode, but as soon as I switch to another mode, box, planar it disappears. Although, when moving the camera around – panning, rotating, zooming – it shows, then disappears again when static!
It’s a physically based material type, with a noise texture in the bump channel.
Any tips would be appreciated. .3dm, screenshots and system infos for v8 & 9 attached.
Thank you
Texture Test.3dm (980.8 KB)
Rhino 9 SR0 2025-6-3 (Rhino WIP, 9.0.25154.12305, Git hash:master @ b2cb56992953ffb81127629b4e1bf5c51cae7c53)
License type: Commercial, build 2025-06-03
License details: Cloud Zoo
Expires on: 2025-07-18
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 9.0.5
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Hybrid graphics configuration on OpenGL
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 6-4-2025 (M-D-Y).
Primary OpenGL: NVIDIA RTX A1000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 5-12-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 573.24
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-12-2025
Driver Version: 32.0.15.7324
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\KeyShotRhinoPlugin (78243fe3-17a0-4865-b713-88b4c224c48c)\1.5.0.0\KeyShotRhinoPlugin\KeyShotRhinoPlugin.rhp “KeyShotRhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 9 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 9.0.25154.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.25154.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.25154.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.25154.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.25154.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.25154.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.25154.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Rhino 8 SR17 2025-2-12 (Rhino 8, 8.17.25043.10001, Git hash:master @ 384a84c165ff11e0681af87e076dd465f8a325d5)
License type: Commercial, build 2025-02-12
.NET 7.0.20
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\KeyShotRhinoPlugin (78243fe3-17a0-4865-b713-88b4c224c48c)\1.5.0.0\KeyShotRhinoPlugin\KeyShotRhinoPlugin.rhp “KeyShotRhinoPlugin” 1.0.0.0
C:\Program Files\Cyberstrak\R8\CS_ModelingPlugIn.rhp “Cyberstrak Modeling PlugIn”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.17.25043.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.17.25043.10001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.17.25043.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.17.25043.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.17.25043.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.17.25043.10001
Hi @sach,
Thanks for this report. This looks like a bug with planar mapping and bump maps. I’ve filed it as https://mcneel.myjetbrains.com/youtrack/issue/RH-87846 . In the meantime, do a custom Unwrap instead with no seams selected.
You may also need to adjust the bump strength settings in the advanced section of Options for RhinoCycles. This will impact Raytraced and Rhino Render if you plan to use them instead of only Rendered mode.
Thanks Brian. I’ll give this a whirl.
