Texture mapping
A basic question. Is there any way to control the direction of each face individually?
If I use Rotation in the texture mapping panel, I only ever get one or two sides they way I want, but not all 3 (front, side, top).
I basically want the grain to run longitudinal to the face in all directions. is there a way to do this?
ok, so I managed to do it with the texture mapping widget.
but it’s a few more steps. OUld be great if these sorts of changes could happen in the panel somehow?
Hi @Andrew ,
I’d use the UVeditor to rotate the islands for each face as needed. You’d also need to make sure the material’s texture is set to mapping channel 1 not WCS.
