Texture mapping widget 🐛?
I received this file from a coworker and when I went to change the size of the mapping, the widget does not match the size of the map in the properties window. Here in the properties window the size of the map is 48,48,48, but when I measure the size of the widget it is 48,48, 8’-1 7/8". Coworker does not recall what he might have done to get the disconnect between the size of the widget and the properties.
Thanks,
Sam
(can’t add space here because the edit is too similar, that should do it)
OddWidget.3dm
Also looks like emoticons don’t work in thread title :bug:
Thanks, this is now http://mcneel.myjetbrains.com/youtrack/issue/RH-19684 (no, you can’t see the contents of the bug - yet)
I have seen this problem today too. It was caused by scaling the object. The widget is automatic scaled, but not the numerical fields.
