Texture issue when zooming
I noticed this issue when zooming a "larg"e texture 6690x4000 pixels applied to a plane.
Transparency is set to zero.
Can you share the file that shows this issue?
Hi Gijs,
here the comparison with Rhino 7 (no issue) and Rhino 8 (visible issue)
I also attache here the file
sketches.rar (12.0 MB)
I can’t reproduce this issue here. Is there any chance you could exchange your AMD card for an NVidia one to see if that resolves this and other issues you are having?
Hi Gijs,
now I tested the same scene using as main output the RTX2080Ti.
As you can see the problem exists also using the Nvidia gpu.
