All textures are glitching when applied to objects
Ive had someone else open the same file and it appears fine for them, so seems like an internal issue.
Hi @Danielle
First thing to do is to run the SystemInfo command in Rhino and post the resulting text here - that’ll help in identifying any graphics card/driver issues. Also, please post the 3dm-file.
HTH, Jakob
Hi @Normand
Thanks for the reply
colours for renders.3dm (4.4 MB)
Using any texture results in the above image, or no texture shows at all.
Rhino 8 SR27 2026-1-19 (Rhino 8, 8.27.26019.16022, Git hash:master @ a7029e543145704b986eede4bc40b6bd8a0645d0)
License type: Educational, build 2026-01-19
License details: Cloud ZooApple macOS Version 26.2 (Build 25C56) (Physical RAM: 32GB)
Mac Model Identifier: MacBookPro18,2
Language: en-NZ (MacOS default)
.NET 8.0.14Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Color LCD (1728 x 1117 @ 120.00Hz)
LG HDR 4K (2560 x 1440 @ 60.00Hz)
GPU Vendor: AppleUSB devices
LG Electronics Inc.: USB ControlsBluetooth devices
NoneThird party kernel extensions
NoneThird party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_DarwinFoundation1.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswift_DarwinFoundation2.dylib
/usr/lib/swift/libswift_DarwinFoundation3.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftCoreMediaIO.dylib
/usr/lib/swift/libswiftCallKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/updaters/libAppleTconUARPUpdater.dylib
/usr/lib/updaters/libT200Updater.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Library/Chaos/Enscape/Enscape.Rhino.Plugin-net48/libSkiaSharp.dylibRhino plugins that do not ship with Rhino
/Users/[Redacted]/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/Enscape.Rhino8.Plugin.rhp “Enscape.Rhino8.Plugin” 4.14.0.668Rhino plugins that ship with Rhino
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.27.26019.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.27.26019.16022
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.27.26019.16022
I’m seeing this as well, interestingly it OK in the Rhino 9 WIP on Mac & Windows Rhino 8. Tahoe and Sequoia show the same issue.
RH-91882 Textures Glitch in Mac Rhino 8.
Please update to 8.28 if you are seeing this issue.
Yes! works thanks
