Hi everyone,
I am in trouble with TextBox.TextChanged
event. When I tried to change value in TextBox
in order to manipulate geometry, it doesn’t wait me complete what I want to type in TextBox
. For example, When I want to type 284 in to TextBox
, TextBox.TextChanged
event firing immediately after 2…
Lets look it in example.
using Eto.Forms;
using Rhino.Geometry;
using Rhino.UI;
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.Linq;
using System.Windows.Input;
namespace TestObject
// This class is inherited from EtoCollapsibleSection
public class TestObjectCollapsibleSection : Section
#region Fields - Eto.Forms Controls
private readonly LocalizeStringPair caption;
private Label testLabel;
private TextBox testTextBox;
#endregion Fields - Eto.Forms Controls
#region Properties
public TestObjectController TestObjectController { get; set; }
/// <summary>
/// This property overriden from Section class to define unique caption of related section
/// </summary>
public override LocalizeStringPair Caption
get { return caption; }
///<summary>
/// The Heigth of the section, it is calculated from height of content that
/// defined InitializeLayout() method
///</summary>
public override int SectionHeight
get
return this.Content.Height;
#endregion Properties
#region Constructor
public TestObjectCollapsibleSection (TestObjectController testObjectController)
caption = new LocalizeStringPair("Test Section", "Test Section");
TestObjectController = testObjectController;
InitializeComponents();
InitializeLayout();
RegisterControlEvents();
#endregion Constructor
#region Initialization methods
private void InitializeComponents()
testLabel = new Label()
Text = "Test Value:",
VerticalAlignment = VerticalAlignment.Center,
TextAlignment = TextAlignment.Right,
Width = 100
testTextBox = new TextBox()
Text = "0",
Enabled = false
private void InitializeLayout()
TableLayout layout = new TableLayout()
// Padding around the table
Padding = 5,
// Spacing between table cells
Spacing = new Eto.Drawing.Size(15, 15),
Rows =
new TableRow(testLabel, testTextBox),
Content = layout;
/// <summary>
/// Struggling with this event,
/// It's not wait to complete what I want to type
/// </summary>
/// <param name="sender"></param>
/// <param name="e"></param>
private void TestTextBox_TextChanged(object sender, EventArgs e)
UnregisterControlEvents();
double newValue = double.Parse(testTextBox.Text);
TestObjectController.ChangeSelectedTestObjectParameter<Height, double>(newValue);
private void TestObjectController_TestObjectSelected()
// Fill textBox here according to geometry has selected, for example
// Height of the box
// Let's assume that this guid object's guid
Guid guid = Guid.Empty;
testTextBox.Text = TestObjectController.SelectedTestObjects[guid].Height.ToString();
testTextBox.Enabled = true;
private void TestObjectController_TestObjectDeselected()
testTextBox.Text = "0";
testTextBox.Enabled = false;
private void RegisterControlEvents()
TestObjectController.TestObjectSelected += TestObjectController_TestObjectSelected;
TestObjectController.TestObjectDeselected += TestObjectController_TestObjectDeselected;
testTextBox.TextChanged += TestTextBox_TextChanged;
private void UnregisterControlEvents()
TestObjectController.TestObjectSelected -= TestObjectController_TestObjectSelected;
TestObjectController.TestObjectDeselected -= TestObjectController_TestObjectDeselected;
testTextBox.TextChanged -= TestTextBox_TextChanged;
#endregion Initialization methods
// let's assume that TestObject simply Box object as brep
public double Height { get; set; }
public Curve BorderCurve { get; set; }
public TestObject(Curve curve, double height)
// There is a method which is creates Brep using with curve and height
public class TestObjectController
public Dictionary<Guid, TestObject> TestObjects { get; set; }
public Dictionary<Guid, TestObject> SelectedTestObjects { get; set; }
public TestObjectController()
TestObjects = new Dictionary<Guid, TestObject>();
SelectedTestObjects = new Dictionary<Guid, TestObject>();
public event TestObjectEvents.TestObjectSelectionEvents TestObjectSelected;
public event TestObjectEvents.TestObjectSelectionEvents TestObjectDeselected;
internal void ChangeSelectedTestObjectParameter<T1, T2>(T2 newValue)
// this method recreates this object and handle dictionaries
public class TestObjectEvents
public delegate void TestObjectSelectionEvents();
Has anyone suggestion for best practice for TextBoxes?
Thanks in advance
-Oğuzhan
