error.gh (12.1 KB)
I’m trying to connect two sets of data to a colour swatch. The component shows a text to geometry conversion error.
error.gh (12.1 KB)
because you have no geometry, only text, which the geometry preview component cannot read as geometry, because it isn’t, yet - if your intent was to preview text as geometry maybe look into FabTools plug-in or the Heteroptera plug-in - both have text-to-object or text-baking options
google will save you:
Once your text is converted to an object then it may be previewed through the component you were using.
Best
also this is why not all your text converts to numbers:
Make sure to clear (backspace) that empty line
Thank you. It works now.
