I’ve just tried generating text tags from within a cluster.
So long as I’m editing the cluster (edit box is open) the tags work fine and show in the Rhino window.
As soon as I save and close the cluster they stop working.
Should the tags work from within a cluster?
Or am I doing something wrong?
Or a work around…
Same here : Text tags inside clusters don’t display
You need to turn on “Preview Contents” on the cluster otherwise it will only preview cluster outputs.
