Text Size While Saving
@enric While saving the following happens with text. The behavior is only present when VA is installed and active. Model units are meters, layout units are mm.
Just a minor annoyance. Thanks for looking into it.
Hello @silvano,
It is just a visual issue, right? Please, could you send us the file?
Hello @alfmelbev , yes, this is only a visual issue. It is only happening with text in VA objects, e.g. section markers, spaces, etc. Please find an example file below. If VA is not loaded, the text always displays in the large size it has during saving (please see screenshot).
Uploading: Untitled.3dm…
Hello @silvano,
I cannot download that file, please, could you share it again?
Untitled.3dm (7.0 MB)
Hello @silvano,
I still couldn’t reproduce the issue. Do you have any other plug-ins installed in Rhino? If so, please, try to disable them to check if you still can reproduce the issue.
