I ran into an issue with right aligned text.
The editor in the tab panel does not focus on the right side making the text invisible.
I need to scroll to the right before being able to edit the text.
Hi Willem - I see this too - the Properties does show the right aligned text if it starts out wide enough, but not if it is too narrow. In any case, I believe the alignment is due to change soon and only show the contents, leaving the actual text in the viewport to show alignment and wrapping.
Hi. Yes, that’s right. In the next WIP the text box won’t have a horizontal scroll bar and “Wrap text” will be gone. Setting the wrap width will only be done in the viewport.
