Text preview too large compared to the rest of UI
Is it possible to scale down the text in the edit text window? It is almost 5 times larger than the rest of the UI texts, which makes it inconvenient to edit.
@Alain what ever happened to the fix for this?
Hi - we are currently working to make this the same size as the rest of the UI.
Hi @wim,
Also the stacking brackets button is not working, also could you please make those things wysiwyg in the editor, and a power button could be very useful.
Thank you!
p.s. text is still too large
Hi Bogdan -
I’m not sure what that means. It seems to be working here.
That’s probably a tall order but I put it on the list as RH-60231.
This one is on the list as RH-35493.
That’s correct - RH-50317 is still being worked on. This thread should get a notification when it gets done.
I’ll make a video. I’m searching for a good and clean screenrecording app. Any suggestions ? :slight_smile:
I was able to copy-paste the symbols from the charmap. ² ³ ½
Hi @wim here’s a video with the stacking brackets button not working
RH-50317 is fixed in the latest WIP
Finally!
Thank you very much! I will now switch to V7 for my day to day work…
cheers
rabbit
Hi Bogdan -
The way this works is like this:
2020-09-24 Stacked Dim
You need to select a fraction.
ok, a little bit counterintuitive :slight_smile:
