nicovlogg
(Nico van Loggerenberg)
May 23, 2019, 1:48pm
1
Hi all
An error I have been getting often is when I click on a text box to edit it, the options in the right hand window pane are all invisible, until I mouse over them and they get ‘revealed’ one by one.
I am attaching a video to show this more clearly as well as the file it happened in last.
Errors.3dm (2.1 MB)
Willem
(Willem Derks)
May 27, 2019, 9:29pm
2
I want to chime in and let you guys know I have this behavior as well.
It seems a hit and mis if the text panel is displaying correctly or not.
-Willem
Rhino 6 SR15 2019-5-21 (Rhino 6, 6.15.19141.8361, Git hash:master @ 909b4c6880294c7dc68b81c149edcd0f71a897cb)
License type: Commercial, build 2019-05-21
License details: Cloud Zoo. In use by: Willem Derks ()
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: WD10
Hybrid graphics system.
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 5-17-2017 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 3-17-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 419.67
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2019
Driver Version: 25.21.14.1967
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp "Commands" 6.15.19141.8361
C:\Program Files\Rhino 6\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Iris (1cd9c8f5-c901-426c-8e80-d6a2e2b18bba)\1.0.6911.20081\Iris.WinR6.rhp "Iris" 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp "Rhino Render"
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 6.15.19141.8361
C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp "RhinoCycles" 6.15.19141.8361
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 6.15.19141.8361
C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp "Displacement"
C:\Users\Willem\AppData\Roaming\McNeel\Rhinoceros\packages\6.0\rhino-render-next\0.0.2\RhinoRenderNext.rhp "Rhino Render Next" 0.0.2.0
nathanletwory
(Nathan 'jesterKing' Letwory)
May 27, 2019, 11:11pm
4
Already reported several months ago - https://mcneel.myjetbrains.com/youtrack/issue/RH-51854
I’ll see if I can escalate this.
Since you’re running a “Hybrid” display setup, Windows gets to choose what parts of an application use the Intel chip and which use the nVidia.
You’re Intel driver is old.
Your GeForce driver seems new enough.
Download the newest driver from Intel.
You may need to use these instructions to load it:
Rhino 6 likes up to date video drivers, and “update your video drivers” is a frequent refrain on this forum. However if you have an Intel graphics adapter which was originally furnished with a “customized” driver it may appear impossible to update the driver with the latest from the Intel website.
I have found a method to get around the blocking of the driver update and manually install the driver update. The key is to use Device Manager to uninstall the adapter after checking the box to delete…
nathanletwory
May 27, 2019, 11:23pm
6
FWIW I see this on my GTX 1060 as well (non-hybrid setup).
The very simple steps from the latest bug that duplicated the one I linked should get you to the disappearing panel quickly:
JoergH
May 28, 2019, 12:01am
7
Same with pure Quadro K3000M
