Is there any possibility to create a text on a planar surface?
decals, or move the text to the surface. for text you may have to use the draw order bring to front etc.
thats pretty open, would you need the text to be editable and/or what else would you expect from such a script? only planar surfaces or does it involve curved surfaces?
Thank you for your reply. I need just an editable text on only planar surfaces
you can do this manually by setting the cplane to the surface:
_cplane _surface
or combine everything in the macroEditor:
_CPlane _Surface _pause _enter _enter _Text _pause _cplane _undo
hope that helps, -tom
i wanted to suggest that and save the makro for myself either, you were faster
