Hello Guys, could you please tell me how to add text to a 3D view using Rnino Inside? The regular grasshopper node doesn’t show it, but the text doesn’t either.
used revit 2022
@Foxman Text notes are view specific Elements. They will only work in view like plan or Drafting views
Thank you for your reply.
Is there a way to see the text that’s visible in Revit in the 3D view? Standard nodes aren’t displayed as text in Revit.
@Foxman You can use query Graphical Element Component and use 3D view as an input. further you can filter out the object you want from the 3d view or exclude from the 3D view
@Foxman as i said texts are view specific elements and you can only view or extract them from plan views.
If you are are using model text then you can visualize them in 3d
